Adjusting Device faders
PhilVale
Post by PhilVale » Tue Jan 31, 2023 4:52 am
Did I imagine it, or was there a plan to enable adjustment of Aduio channel devices via the SFR command?
If so what happened to it as I can't actually find it at the moment.
Might be useful as although I can do it via a midi message to my interface unit (a Beheringer X18 and I usually tend to map one SCS Output chanel to a specific input chanel on the mixer) but there's no fade time when I do it that way.
Re: Adjusting Device faders
Post by Mike Daniell » Fri Feb 03, 2023 6:38 am
Not sure how an SFR cue fits into this requirement. Do you mean you want a cue type that will adjust channel levels in the Faders Window ?
PhilVale
Post by PhilVale » Fri Feb 03, 2023 7:32 pm
Yes Mike,
I thought we talked about it a little while back maybe I'm wrong.
Didn't think we got to the point of having a different cue type though just an option on an existing cue type like SFR or maybe Level Change woould be more appropriate.
No biggie if it doesn't seem right or is a heap of work.
Phil.
