New warning message in 10.1.2 (fix in 10.1.3)
Martin
Post by Martin » Fri Aug 29, 2008 7:12 pm
The new warning message for "orphan" manual cues is fine for SFR cues but does not seem to work for Level Change cues.
Re: New warning message in 10.1.2
Post by Mike Daniell » Sat Aug 30, 2008 9:54 am
Oops! It was working before I changed the processing of the SFR warning. Fix ready for 10.1.3.
Martin
Post by Martin » Sat Aug 30, 2008 5:30 pm
Mike - That's fine. Thanks.
Martin
jmgordon
Post by jmgordon » Tue Sep 02, 2008 9:04 am
On a 1280 x 1024 display the warning label wraps to two lines, the second of which is partly obscured by the Windows task bar.
Perhaps an additional fix for 10.1.3 ?
Post by Mike Daniell » Tue Sep 02, 2008 9:36 am
jmgordon wrote:On a 1280 x 1024 display the warning label wraps to two lines...
What cue labels do you have, Malcolm? I checked 1280 x 1024 with labels like Q3 and Q4 and the message doesn't wrap, but it is getting close to the maximum width. Could you email me a screen shot?
Edit: I've reproduced the wrapping by using longer cue labels. Fix ready for 10.1.3, tested on all standard screen sizes from 1024x768 to 1920x1200. I've slightly changed the wording, removing one of the cue label references, and if the message is still too wide then the word 'warning!' is removed from the start of the message.
