Deleting times on time-based cues (fix in 9.5.1)
TimW
Post by TimW » Tue Dec 04, 2007 4:43 pm
High Mike.
I had inadvertantly set my time for an evening performance instead of a matinee. When I tried to delete the time, it defaulted to 'manual' instead. It also will not let me put a '0' figure in for a default, which is good.
The only way I have figured out to correct my mistake is to delete the cue and reload it. It isn't that much of an ordeal, just time consuming.
Is there something I am missing, or is it not possible yet to just delete an entry on the time for a time-based cue.
Thanks, Tim
Post by Mike Daniell » Tue Dec 04, 2007 9:18 pm
That looks like a bug, Tim. I'll get that fixed in 9.4.7. Meanwhile you could set the time to something like 3:00am so that the cue is 'completed' when you select the applicable time profile (assuming you start the program after 3:00am!). But deleting and re-entering the cue as you suggest would give a better result.
