x32 Cue Control cannot be activated error
msinklair
Post by msinklair » Thu Nov 30, 2023 5:38 am
When I load an existing cue file that was using cue control from the X32 I get an error.
CUE CONTROL
* Network In device 'server:port=192.7.29.92:10023' cannot be activated
To get it to work, I have to review the device map and make the cue control a dummy connection. I then have to send a command to the X32 from my cue file. Sometimes that will fail a few times. After it is successful, I can then un-dummy my network in and it connects and works fine. If I save the cue file with it dummy'd, then I can load without error. I still have to send a command, until it succeeds, before I un-dummy.
Any thoughts on this?
dee99
Re: x32 Cue Control cannot be activated error
Post by dee99 » Thu Nov 30, 2023 6:53 am
Can you send a description of the problem and a log file from a run with the problem to support@showcuesystems.com
The log file can be found in your documents\scs logs folder.
If you send several logs please label them or let us know in the email detail for that run, thank you.
msinklair
Post by msinklair » Fri Dec 01, 2023 6:11 am
Sure thing. I'll try to get to it tomorrow.
msinklair
Post by msinklair » Thu Dec 14, 2023 2:15 am
I was able to finally send the email. I'm sorry it took longer than expected to get to it.
msinklair
Post by msinklair » Mon Jan 01, 2024 9:33 am
Just wanted to follow up that my issue has been resolved thanks to the prompt support. Thank you very much!
