Hi there,
is there any limitation regarding the number of files or overall filesize for a slideshowcue.
I have a bunch of 395 photos to slide and scs crashes every time i try to load the files (JPG, 960x540, 24Bit, all between 15kB and 40kB).
Uwe
Slideshow limitations
Re: Slideshow limitations
What's the error message you get? Also, if possible can you email me a diagnostic file, preferably compressed? You can create this file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
Hello Mike,
here is a link to the screenshots i made. The last one shows the error message.
unfortunally its not possible to create a diagnostic file, because scs seems not to be active after that.
https://www.dropbox.com/sh/fz1kxrqjyt78 ... zi3_a?dl=0
meanwhile i created a moviefile with all the photos. but i know, i get in trouble if only one simple photo have to change...
Best regards,
Uwe
Best regards,
Uwe
Sorry, first i did not understand the diagnostic file thing.
I added the file to the link.
Uwe
Uwe
Thanks for the info and files, Uwe. The error occurs on loading the thumbnail images. I should have a fix available for this shortly.
