Bluetooth Speakers
Kay
Bluetooth Speakers
Post by Kay » Wed Jul 19, 2017 10:02 pm
I would like to be able to switch back and forth from a Bluetooth speaker to a wired speaker. When I map a device, it seems that device must always be present. I would like to have a wired speaker and Bluetooth speaker mapped but maybe only use one of them on a particular occasion. Is there a way to do this without changing each cue manually each time I want to switch speakers?
Eric Snodgrass
Re: Bluetooth Speakers
Post by Eric Snodgrass » Thu Jul 20, 2017 1:39 am
What output are you using for your computer?
Is this for a particular show where you are using both the Bluetooth speaker and the other speakers or do you use these for separate shows/events?
Post by Mike Daniell » Thu Jul 20, 2017 4:56 am
You can set up two 'device maps' in SCS - one that uses the Bluetooth speakers and another that uses the wired speakers. If SCS doesn't automatically select the required device map then you can switch the device map via the Device Map button on the main screen.
