[Mod 11.5.2.1] Question about memo cues
rborsey
Post by rborsey » Mon Sep 19, 2016 4:42 am
Hi. In the manual it says that memos stay displayed until another memo cue is fired, or until it is closed on timeout or it is closed manually. I find that they are closed if I trigger an audio or SFR cue using an external trigger. Is this normal?
Cheers from sunny France
Richard
Re: Question about memo cues
Post by Mike Daniell » Mon Sep 19, 2016 12:15 pm
I've just run a test here with a Memo cue displayed and then starting an Audio File cue by external control (MIDI) and the Memo cue correctly remained being displayed.
Post by Mike Daniell » Tue Sep 20, 2016 10:39 am
Thanks for the diagnostic file and further info. I've applied a mod in 11.5.2.1 which prevents the 'Go To Cue' from closing a later Memo cue if that Memo cue was started by an external trigger or hotkey. I think that will be universally acceptable - otherwise I would need to add an extra property to the 'Go To Cue' specifically to keep such Memo cues alive.
rborsey
Re: [Mod 11.5.2.1] Question about memo cues
Post by rborsey » Tue Sep 20, 2016 6:02 pm
Many Thanks Mike. Just downloading it and I'll be running through as et later today . . .
CHeers
Richard
