[Fix 11.5.2] Timed delays not working in 11.5
genel
Post by genel » Sun Aug 28, 2016 8:19 am
I updated to 11.5 and discovered that all delayed cues or sub cues fired immediately. I updated to the pre release and it still happened. I fell back to 11.4 and all cues worked. I also tested with a simple show of 1 cue with subcue and it didn't delay the subcue. Attached is the test cue file.
Re: Timed delays not working in 11.5
Post by Mike Daniell » Sun Aug 28, 2016 8:34 am
The cue file doesn't appear to be attached to your posting. Could you email it to me, or email me a diagnostic file? You can create a diagnostic file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents".
genel
Post by genel » Fri Sep 16, 2016 11:40 am
Mike sent me a new version of SCS and that cured the problem. He spent a lot of time on this and another issue,
Thanks Mike!!
