Audio cue bookmarks
howartp
Audio cue bookmarks
Post by howartp » Fri May 06, 2016 7:17 am
During rehearsals for dances, our choreographer often asks "can we go back to that bit where ....."
I then find that bit and make a mental note for that rehearsal, but by the time we rehearse that dance again in 2 weeks time I've forgotten the timings.
I wondered whether a bookmark type feature could be added to the audio cues?
We set the start and end times of the full track as it will be played 'on the night', but then add one or more selectable start points for rehearsing to. These would be added either in the Editor, or under the 'Save settings' button (if I pause a cue at 1:32 and go to Save Settings > Create bookmark for cue 3).
Then in the playback area, alongside any cue with bookmarks, a dropdown box to select the bookmark would appear?
I've attached a dummy screenshot, with dropdown box overlaid from some other software. :)
Peter
Re: Audio cue bookmarks
Post by Mike Daniell » Sun May 08, 2016 12:34 pm
I've had some requests for 'SCS Markers' for audio file cues, ie markers that can set within SCS. So your suggestion could fit in with this as well.
acheslow
Post by acheslow » Sun Feb 25, 2018 5:55 pm
+1 for the same use case
