[Fixed] Start before end of cue XXX not always working
rborsey
Post by rborsey » Mon Feb 10, 2014 6:06 pm
SCS 11.2.4 : I have audio cues with loops pretty close to their start (for vamp intros to songs) and a lighting control midi file cue which runs in parallel. When the loop is released the lighting cue file is stopped immediately and then I have a 2nd lighting cue file which starts automatically based on the audio file end (ie to start the lights file running just after the loop is exited). I think this is the only way to do it as midi files can't have loops. With SCS 10 this has been working reliably and with good synchronisation. I upgraded to SCS 11 and now sometimes the 2nd lighting cue file starts, sometimes it doesn't. Tried this using ASIO and Directsound as my audio engine - same problem.
All help appreciated
Richard in sunny (actually very wet) France
Re: SCS 11.2.4 Start before end of cue XXX not always workin
Post by Mike Daniell » Mon Feb 10, 2014 7:41 pm
What audio file format are you using? MP3?
Could you email me a diagnostic dump file? You can create this file by starting SCS and selecting 'Create Diagnostic Dump File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Dumps" under "Documents" or "My Documents".
rborsey
Post by rborsey » Tue Feb 11, 2014 5:04 pm
Howdy. Dump file just created and sent with more info. In answer to your query my audio files are all wavs.
Cheers
R
rborsey
Post by rborsey » Fri Feb 21, 2014 5:43 am
Hi - did you get my new dump file and mail last week?? I did make a mistake with my calculations on cue 17 but cue 72 should be OK etc . . .
Cheers
Richard
Post by Mike Daniell » Fri Feb 21, 2014 8:47 am
Yes, dump file received but I still can't see why this fails and so far haven't been able to reproduce the error. I've emailed you details of a tracing version to run.
rborsey
Post by rborsey » Mon Mar 10, 2014 9:47 pm
A huge thanks to Mike who has chased down this problem, solved it, and supplied a fix. Bravo!!
Warm greetings from a (finally) hot and sunny France
