Lost my "Go" Button
derekr
Lost my "Go" Button
Post by derekr » Sun May 15, 2011 8:48 am
was running all my track playbacks tonight on show (aprox 60 tracks with fade cues) half way through i lost my "Go" Button and space bar would not work. had to start each cue by pressing play on the cue. this is the 2nd time its happend to me.i'v att. aphoto of the display as it happend tonight during the show.
Need help as i have another show tommorow with the same tracks.
Derek
fr_142_size1024 (Medium).jpg (81.14 KiB) Viewed 711 times
jmgordon
Re: Lost my "Go" Button
Post by jmgordon » Sun May 15, 2011 9:47 am
Interesting to note that, whilst the "Go" button is frozen off, the "Print" button appears to be frozen on, and the Next Manual Cue indication is missing. Did the freeze happen at Q43 the first time?
When I encounter odd behaviour (admittedly not recently) one of my first actions is to reinstall SCS in case it has become corrupted somehow, assuming you have the download saved somewhere.
Has this particular show played through without problems previously? What version of SCS are you running?
Post by Mike Daniell » Sun May 15, 2011 10:16 am
The "Go" button is disabled because Q49 is "Not Loaded". The reason it is not loaded is probably because you are running several cues back-to-back, and SCS generally will not load an audio file cue while another audio file cue is currently playing. This is to avoid the possibility of sound breaking up during loading another file. (I have made some changes in that area, so which version of SCS are you running?)
The solution is to increase the "Max. No. of Audio Files to Pre-Open", which is under General Options / Permanent Options. SCS opens audio files when no other audio files are playing, so by increasing this setting you are allowing SCS to look further ahead in the cue list. The maximum setting is 50.
The point about the "Print" button being highlighted is just a minor timing issue. When the mouse hovers over one of these buttons, the button is highlighted. Sometimes the button remains highlighted after you've moved the mouse away from the button. I haven't worked out why, and it doesn't affect the run.
derekr
Post by derekr » Sun May 15, 2011 6:09 pm
Hi mike, im using 10.7.6 iv been running scs on this laptop for years with never any prob. Ill up the amount of preloads an see if that helps.
I did notice as i was loading in the tracks in it took about 20 sec before it would be ready to add another cue in. Each track is about 3 mins in lenth.WAV format.
Derek
Post by Mike Daniell » Sun May 15, 2011 6:25 pm
derekr wrote:I did notice as i was loading in the tracks in it took about 20 sec before it would be ready to add another cue in.
That's strange. Let me know when you've finished this show and I'll send you details of a trace version to see if we can find out why it takes so long.
derekr
Post by derekr » Sun May 15, 2011 7:32 pm
Will do :D
Eric Snodgrass
Post by Eric Snodgrass » Tue May 17, 2011 2:17 am
When was the last time you cleaned up the laptop's hard drive, archived and removed any old shows and defragmented? Do you do this regularly? I ask because you stated that you've been using this laptop for years.
