File Name or Cue Name?
modellbahner
Post by modellbahner » Mon May 10, 2010 9:15 pm
Is it possible to select wheter the cue name or the file name (which ist actually displayed by default) is displayed in the player at the main view.
Re: File Name or Cue Name?
Post by Boswell » Tue May 11, 2010 2:54 am
Yes, depends how you make the cue.
If you give the cue a name before you select the file then the cue name is used.
If you leave the cue field blank and select the file then the cue field is auto-populated with the file name.
So it's down to you on the sequence you use for making the cue in the editor.
I've done this reply from memory and as I'm old, it might be wrong! :?
