SCS 11.10.7
SCS is receiving the following commands ok and executing…
/ctrl/go
/ctrl/gotop
But if I send …
/cue/go ,s x
/hkey/go ,s
These are received but not executed.
To test further I connected 2 laptops running SCS and used the “test network control” on the receiving laptop to see what was being received. See image.
Some OSC commands not working
- IMG_8700.jpeg (98.41 KiB) Viewed 6454 times
Re: Some OSC commands not working
Please email us the log file from the run in which this happened. Log files are saved in a folder named "SCS Logs" under "Documents", and the name of each file includes a time-stamp indicating when the log started. Email to support@showcuesystems.com
Files sent.
Thank you.
Thank you.
