So is it possible to implement multiple Production Timers.
Rational - I usually set a production timer running at the opening cue of Act I then stop it at the closing cue of the act. Then either resume or restart at the starting cue of Act II and stop on the curtain call cue.
What would be good is to allow multiple Production Timers along the bottom that can be triggered. Personbally I'd use one for each act and on for the interval. (I often get asked how long of the interval have we had or have left).
Any chance? I would hazard that a max of 5 timers would be appreceiated but others. Like I say personally I'd probably only use 3. But I could see using more if they were there.
Thanbks in advance,
Phil
Multiple Production Timers
Re: Multiple Production Timers
Could do. As well as adding a timer number column in the Production Timer screen, we would probably need to support two 'Production Timer Action' (and Timer Number) columns, so that one timer can be stopped (or paused) and a second time started (or resumed).
Yep thinking it through a littkle further I can see that. If it's possible.
Thanks as always Mike.
