[Fix 11.10.0] when changing operatioan mode menu doesnt change
Hi, I am using 11.9.8 (brilliant thanks Mike) when I change the operational mode from design /rehearsal to Performance, the menu bar does change unless I quit and restart.
Re: when changing operatioan mode menu doesnt change
Works for me, make sure you click on 'Apply' and 'OK' after you make the new selection ( 11.9.8 )
No, it seems that Steve is correct. I've just run tests switching from Design Mode to Performance Mode, and then Performance Mode back to Design Mode. After each change I had to close and restart SCS for the toolbar icons to change.
Mike will a fix for be avaiable soon?Mike Daniell wrote: ↑Sat Jan 21, 2023 7:27 pmNo, it seems that Steve is correct. I've just run tests switching from Design Mode to Performance Mode, and then Performance Mode back to Design Mode. After each change I had to close and restart SCS for the toolbar icons to change.
