Problem using "call cue"
Peter 55
Post by Peter 55 » Mon Aug 20, 2018 9:16 pm
I'm a newbie, so my apologies if my problem has already been raised. I'm using the professional version 11.7.0 64 bit.
I have an audio file cue which I need to use a number of times. When I attempt to add a "call cue" cue; the call cue window in the cue properties window does not list any of my audio cues. I suspect I'm not doing something correctly. Any help would be much appeciated.
Peter
Re: Problem using "call cue"
Post by Buyaicia » Mon Aug 20, 2018 9:51 pm
You must set "activation mode" as "Callable" for the audio cue you want to call repeatedly.
Peter 55
Post by Peter 55 » Tue Aug 21, 2018 1:34 am
Blindingly obvious now you've told me.
Many thanks.
Peter
