It would be great if there was a midi cue control command similar to the master fader level that controlled the fader of the active cue.
I often have a single tech run to adjust and save audio cue levels before the live show. It would be much easier to fine tune each cue's volume using a midi control surface instead of a mouse.
Midi cue control of current cue fader
Re: Midi cue control of current cue fader
As a workaround I just found an old Griffin Powermate I had laying around and was able to map the dial so turning it counter-clockwise sends Shift+F11 to turn down the playing cue level and turning it clockwise sends Shift+F12 to turn it up. And as a bonus I can press down on the dial to map it my Go command. Sometimes being a gadget hoarder has its benefits.
