At last I found some time to report a few bugs. So this is my 2nd one. I put it in a new report because of easier future lookup on this forum.
Working with 11.6.2 (x64) and attached the diagnostic file.
The problem is with Q13. In Q5 a playlist is started and in Q6 this playlist is hibernated. Q13 is auto-started and should fade-in in 4 sec the hibernated playlist but it start immediately at nominal level. So no fade-in.
I also believe that the level change cue in Q14 doesn't do anything.
But perhaps I made a mistake with programming?
Hope there will be a solution soon.
Thanks in advance,
Eelco
Problem with fade-in of hibernated playlist
- scs11diag_2018-02-08_154942.txt
- uploading .scsz file wasn't allowed so made it .txt
- (64.01 KiB) Downloaded 41 times
Re: Problem with fade-in of hibernated playlist
Will look into this shortly.
