I was pre programming scs (tested both 11.6.2.0 and 11.6.2.1 windows 10 x64bit) on a computor monitor, it gave a full second screen black and a normal output vieuw. When i put it on the tv (for The customer previeuw) it didnt filled the screen with a black filler and all the video's and photo's were in a squire box with cut edges.
(update) it also accures on video scalers, direct to a beamer is not a problem
It did this one mutiple show files.
in the attachmend is a screenshot of the foul with scs
scs creating small video output window on tv
- scs is full screen on main window everything else (exept the task bar) is second screen
- error scs.png (91.55 KiB) Viewed 485 times
Last edited by MH licht en geluid on Mon Nov 20, 2017 7:23 pm, edited 1 time in total.
Re: scs creating small video output window on tv
Not sure why this would be happening, but could you email me a diagnostic file? You can create this file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents" or "My Documents". This must be created on the computer with the problem tv display.
