Hi Mike!
I've just installed version 11.5.2.1 x64, and an earlier bug came back. I've reported it before:
"Hi!
I am using the rc2 version for my shows now, and 'till now there was no sign of this asio driver stalling issue.
However there is a problem with one of my cues in rc2. There is an auto-start cue (starting ca. 11 secs after the previous) containing 4 audio subcues, each starts in different time relative to each other or to the cue itself. The problem is, that in this version they are not played correctly, causing an infinite loop, replaying the first 5 secs of the cue.
If I modify the relative values, that fixes it, but after a restart, the problem is back again.
Didn't have this earlier, so I hope it will be fixed in the stable release.
Thank You!"
It was fixed in 11.4.2, but I have the same problem in 11.5.2.1. I've attached a diagnostic file, e-mail me a tracing version I could run if it's necessary.
Thank You!
[Fix 11.5.2.2] Sub-cue goes into infinite loop
- scs11diag_2016-09-20_141718.rar
- (18.28 KiB) Downloaded 45 times
Márton Joós
Sound Engineer
Weöres Sándor Theater
Szombathely, Hungary
Sound Engineer
Re: Sub-cue goes into infinite loop
I've emailed you details of the tracing version.
Fixed in 11.5.2.2.
