SCS Crashing when I try to change shortcuts and other options.
Message for short time "invalid memory access" then "Show Cue System has stopped working"
Install on new PC.
David
[Fix 11.5.0] SCS Crashing in options menue
Re: SCS Crashing in options menue
I've emailed you details of a tracing version to run.
I've had the same issue but when trying to renumber Que's. Tried on another pc and got the exact same issue at the exact same point
This seems to be a strange Windows 10 issue, but from similar reports I've received you should find this fixed if you use the 64-bit version of SCS. This is now available as a release candidate of SCS 11.5.0.
