Hello
I was wondering if you could add a option on the Video/Image Options.
I do Alot of kid dance shows which also have a projection screen. SCS is Great for the Audio Side. I would like the Ability to Create a Audio Cue then Add a Sub Cue with the Video/Image for the Projection but then when the Audio Track Finishes it Either Fades or Stops the Video Rather and having to Keep creating a Control Cue to Fade about the Video/Image when the Previous Cue ends. It would make the processes alot Quicker
Grant
Video And Audio Sub/Linked Cues
Re: Video And Audio Sub/Linked Cues
Something you can do now which should help is to create a hotkey SFR cue to 'fade out and stop all playing video/image cues'. Then when an audio track ends you just need to hit the hotkey. Although this requires you to manually fire the 'fade out and stop', at least you only need a single SFR hotkey cue to do this.
