Hi guys,
Is it possible to use the "custom MIDI string" cue in SCS to transmit a MIDI sequence?
Cheers!
Martin
MIDI Sequences
MIDI Sequences
Moderato Maestoso - Creative Music & Technology
http://www.moderatomaestoso.com
Composition, Musical Supervision, Orchestration & Arranging, Keyboard Programming, Audio Software/Hardware Development, and Music Technology Consulting
Re: MIDI Sequences
In a Control Send cue you can select 'MIDI Free Format' to send any MIDI string of up to 255 bytes. This will be sent as a single string. If you need a more complex MIDI sequence, eg with timings of individual commands within the sequence, then you may want to consider setting these up in a MIDI file and using an Audio File cue to play the MIDI file.
Re: MIDI Sequences
Thanks for the reply. Ideally I do actually want to 'play' (transmit) a MIDI file, rather than hand coding MIDI strings! Looking at the audio cue parameters in the demo, I can't see that it lets you open a MIDI file - just WAV, MP3, or WMA. I'm assuming this is just a function (or 'non function'!) of the demo - is this right?
WIll the MIDI file be transmitted through the MIDI out port selected in the permament options? And will the 16 channels be respected in the file?
Thanks!
Martin
Thanks!
Martin
Re: MIDI Sequences
That's correct. MIDI file support is not available in the Demo and requires an SCS Professional or higher license.ModeratoMaestoso wrote:Looking at the audio cue parameters in the demo, I can't see that it lets you open a MIDI file - just WAV, MP3, or WMA. I'm assuming this is just a function (or 'non function'!) of the demo - is this right?
In Production Properties there is a tab for MIDI Play Devices. Here you specify a 'Device name used in cues' and map that to a 'MIDI Playback Device'. If you currently have a MIDI Out (or MIDI Thru) port assigned to the MIDI port you want to use for playing MIDI files then you will need to clear that MIDI Out (or MIDI Thru) port assignment in the Permanent Options as SCS will not let you use the same port for Control Send cues and for MIDI Playback.ModeratoMaestoso wrote:WIll the MIDI file be transmitted through the MIDI out port selected in the permament options? And will the 16 channels be respected in the file?
MIDI playback is performed using standard Windows MIDI software so you should have no trouble playing all 16 channels.
Re: MIDI Sequences
Great. Thanks very much Mike!
