Marker display from Sound Editor to SCS 10+
Carleton50
Post by Carleton50 » Mon Jun 28, 2010 2:34 am
Hello,
I use Sound Forge to edit my audio tracks - and also a Zoom H4N to record voice overs and other recorded bits used in the plays we produce.
I was encouraged when we did J.B. that the recordings I made with the H4N and marked the various spots of good takes and bad takes on-the-fly transferred perfectly well when edited in Sound Forge. In other words, all markers made with the H4N showed up perfectly well in SF.
What I'm getting at is, I wonder if SCS 10+ could also display the markers made by another application so that loop points could be set in the other application and used by SCS?
I think that feature would help setting loop points more exactly.
I'm using SCS 10.7.2 with windows XP pro sp3 with a MOTU 2408 PCI audio interface.
Best regards,
Carleton Underwood
Zanesville Community Theatre, Ohio USA
http://www.zct.org
Re: Marker display from Sound Editor to SCS 10+
Post by Mike Daniell » Mon Jun 28, 2010 2:37 pm
I'll look into this for SCS 11. I presume the markers are standard WAV file 'cue points'.
Carleton50
Post by Carleton50 » Tue Jun 29, 2010 6:49 am
I can e-mail you off-list example files.
Carl
Post by Mike Daniell » Tue Jun 29, 2010 12:31 pm
Carleton50 wrote:I can e-mail you off-list example files.
OK - please email me one file with details of what markers are in the file.
Post by Mike Daniell » Wed Jun 30, 2010 1:55 pm
Thanks, Carl. I was able to extract the cue points from the file you sent me. They are standard WAV file cue points so I will include in SCS 11 the ability to set start, end and loop points from WAV file cue points.
Post by Mike Daniell » Fri Mar 23, 2012 4:40 pm
Cue points/markers now available in SCS 11 Beta 20.
