Save Live Cue Levels
PhilVale
Post by PhilVale » Tue Sep 21, 2021 9:05 pm
Could we get a button that says something like - "Save Cue Levels"
Scenario
When setting Audio cue levels if you have a bunch of cues that are running side by side you usually need to do some mixing with them to get the right balance as they run in conjunction with each other. (as opposed to individyually when you use the editor screen). This can be done using the slides in the bottom half of the screen but as soon as we stop the audio cue then the cue level reverts to what was originally set in the editor screen. SO instead of having to note the new level settings and go back to the editor screen and put them in it would be useful to say - ok That's It - Save those Live Cue Levels off.
Phil.
Re: Save Live Cue Levels
Post by Mike Daniell » Tue Sep 21, 2021 10:16 pm
Does 'Save Settings' in the Main Window Toolbar provide what you need?
Post by Buyaicia » Tue Sep 21, 2021 11:49 pm
I have a shortcut set for this function, is very useful.
PhilVale
Post by PhilVale » Fri Sep 24, 2021 11:12 pm
Looks like it does thanks Mike.
I like the idea of setting up a shortcut too
SCS the tool that just keeps on giving.
sjwicks
Post by sjwicks » Sat Sep 25, 2021 4:22 am
I have set up a button on my Stream deck and assigned it as Shift+F10. Then anytime I need to "save levels" a quick press of the button does the job.
