Interface wirh Numato 32ch ethernet gpio
mookai1973
Post by mookai1973 » Sat Jan 05, 2019 6:29 pm
Hi All,
I would like to use SCS to communication with Numato 32 Channel Ethernet GPIO Module via telnet with SCS but it's not working I don't know I'm make something wrong for command code, I need to use ch.1-16 to trigger scs cue and use scs to control send to ch.17-32 to digital output on Numato,
in below it's link to Numato I'm try to email to them but no reply back,
https://numato.com/docs/32-channel-ethe ... og-inputs/
Numato telnet ip it's 192.168.1.211 port 23
I'm use Windows 10 with SCS 11.8
any advice for me is appreciated.
Thank you so much
Kai
Phuket FantaSea Theatre & Theme Park
KAI
AV Department
Phuket Thailand
Re: Interface wirh Numato 32ch ethernet gpio
Post by Mike Daniell » Sun Jan 06, 2019 5:27 pm
Kai,
I'm not familiar with the GPIO module, but could you email me the SCS log file of a run in which you try to use the telnet interface, and also any relevant details regarding the GPIO setup? For example, do you have to configure the GPIO module to send or receive on specific channels, etc? Regarding the SCS log file, a log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started.
mookai1973
Post by mookai1973 » Sun Jan 06, 2019 5:41 pm
Mike Daniell wrote:Kai,
Dear Mike,
Ok, I will send it but a problem it's not from SCS, SCS working great but a problem it's a command , any way I will send it to you.
Thank you so much,
Kai
KAI
AV Department
Phuket Thailand
