Another little addition that would be really useful would be a button on the main workspace that prevented SCS being triggered by incoming Midi. Basically a quick way of stopping effects being fired by an external source of Midi such as Console Software, in instances like where you are editing a cue on that external software, or rehearsing a text section across a cuepoint and don't want the associated effect to fire every time. One can go into the Options:Midi Control menu tab, and turn off midi control, but that is a bit long-winded for the situation described. A Hotkey, Ctrl-Key combination or similar would be fine, as ling as when activated (ie Midi blocked), there was some sort of message on screen to warn you.
Cheers,
nick
Midi Suspend Button (in 9.4.2)
Nick Reich
System Sound Pty Ltd
