Problem in editor SCS 10.1.1 (solved)
Adair
Post by Adair » Sun Aug 24, 2008 12:55 pm
Hello. I created a 6 cue show.
I'm having some problems with the editor.
In the editor I can't switch cues. The only way I can get to a cue is double click on the cue in the main screen.
When I then I tried to add a cue. It seems to add above the cues I'm editing. Even if I have slected a differnt cue in the left side of the editor
So if it inserts in the wrong place and I delete it does delete, but shows on the top half of the main screen.
If I then save it still shows on the main screen until I refresh the list
Some times when I double click on a cue to open it ion the editor it opens the production properties instead.
I can only move the cue I'm editing up and down the list. Even if i select a different cue in the left side of the editor.
If I choose the Production Tab and choose production properties it does display the producion properties. If I then go back to the cues tab. It stays in the production proprties.
Any thought?
Adair
jmgordon
Re: Problem in editor SCS 10.1.1
Post by jmgordon » Sun Aug 24, 2008 9:46 pm
Sounds unusual behaviour. It might be worth trying a re-install of SCS in case it has somehow become corrupted.
Post by Mike Daniell » Wed Aug 27, 2008 9:16 pm
Thanks for this suggestion, Malcolm. Adair did advise that re-installing SCS fixed the problem. Unfortunately his posting got lost when the servers were changed at the SCS web hosting site.
