Hi folks,
trying to set MIDI interface to the mentioned device (appearing in setup screen as "USB Audio Device") will crash SCS 10.1.0 immediately. SCS 9.5.3 works fine.
OS is WinXP SP2 including latest updates. What could be a problem here? Please ask, if more details are needed.
Regards Jörg
Update: Seems to be an incompatibility with Yamaha's CBX driver (a MIDI to serial port driver), deactivating solves the problem.
Problem with USB MIDI Interface (fix in 10.1.1)
Re: Problem with USB MIDI Interface
This may be fixed in 10.1.1. Could you try re-activating the CBX driver and testing with SCS 10.1.1?
Hallo Mike,
works perfectly with 10.1.1.
Greetings from Zittau, Germany
Jörg
Jörg
