Hi Mike
When starting v10 I get the following error message
__________________
Error Unknown error
SCS 10.1.0
ProcName = createOneMixerStream
BASS_Mixer_StreamCreate failed for FOH
___________________
If I continue, then for every cue I get an error message - Subscript out of range, Proname = OpenMediaFIle (which loops through all the queues, then returns to Q1 again)
I installed V10 with default settings, which left my existing version 9.5.1 still installed (and working)
Any idea for a solution?
UPDATE
I have found the cause of this problem - helped by holding CTRL key when v10 loaded
In my 9.5 SCS files I have the following <PRPhysicalDev0>Playback through TotalRecorder (emulated)</PRPhysicalDev0> which if removed enables the SCS to load and play correctly.
Version 10.1.0 not loading
Andy Terry
Re: Version 10.1.0 not loading
Andy,
After you removed the TotalRecorder line and the program started OK, did you subsequently assign an output to the TotalRecorder device OK? I don't know anything about TotalRecorder, but from a quick look at their web site it looks like some kind of audio driver, and possibly it's incompatible with the audio library used by SCS 10.
Mike
NO, if I try to assign a physical device back to TotalRecorded I get the same error message. I'm not too troubled by this, as I only use TotalRecorder on my home pc, it enables the capture of any sounds passing through the soundcard. It is not installed on our theatre system, but I thought the info might be useful for others using the same software.
Thanks again
Thanks again
Andy Terry
