Next manual Cue (in 10.1.1)
Post by Boswell » Tue Aug 05, 2008 4:22 am
Easy one for you Mike (I think)
A display option to hide the 'Next Manual Cue' that appears under the ribbon bar please :D
Re: Next manual Cue
Post by Mike Daniell » Tue Aug 05, 2008 1:36 pm
Yes, that should be fairly easy, but may I ask why you want to hide this?
Re: Next manual Cue
Post by Boswell » Tue Aug 05, 2008 5:45 pm
To avoid confusing inexperienced operators, I like to have the minimum of info on the run screen, Therefore I remove the ribbon, master vol, hotkeys, subcues unless they are required. The next manual cue fall into this catagory as it is already highlighted by colour change in the cue list. My colour scheme is very dark but the next cue is bright lime green so it stands out. In the heat of a show, the next cue should be easily seen, you do not want the same information visable in two places on the screen, it can get confusing! I want the operators to see the next cue in the context of the cue list so that they might do some anticipation and think ahead (I can dream) :?
Re: Next manual Cue
Post by Mike Daniell » Fri Aug 15, 2008 1:17 pm
Mod ready for 10.1.1.
