I'm having problems with Standby Cues.
I set the Standby Control of an audio file cue (Q3) to 'Set to standby when cue ends'.
After that cue has stopped there is an additional Go button labeled 'Standby Q3-Go!' BUT it is greyed out and not functional.
In addition a strange thing happens when I set one of the following Cues to 'Cancel Standby ...... ' - then the Standby Go! button is removed (thats fine) but the Main GO! button is loaded with Q3 ?!?!?
Edit: As long as Q3 is defined as 'Set to Standby' after 'Stop Everything' its not possible to start at a later Cue. Always jumps to Q3.
Thanks and greetings,
Walter
SCS 9.4.4 Standby Cue (fixed in 9.4.5)
