Example:
Q11 has a 2.5s fade out set
Q12 says to Autostart 2s b4end of Q11.
If let Q11 play to the end, Q12 starts on time.
If I hit Fade out on Q11... Q12 doesn't start until Q11 is has finished.
For many cues this process works fine, but some cues refuse to work right.
I have been having this problem with a few revisions, and hoping each time the newest one would fix it.
ver 9.3.6
Buffers set to 2500 each
All 24bit wav files
Next cue doesn't start on time if I use Fade out (Fixed)
Tested and works in 9.4 rc2
Thank you for fixing the manual fade issue so quick.
It works perfectly!
As for 9.4 rc2 Wow!! Those are all huge functional improvements that will save so much time. And being able to zoom in allows me to produce much higher quality cue points and loops without all the frustration... Thank you!
It works perfectly!
...Don
