9.3.6. print cue list broken (Fixed in 9.4)
d_korman
Post by d_korman » Thu May 03, 2007 8:12 pm
Cue list printing seems broken - each audio file cue now gets printed twice, the first line as expeected, but then a second line for the same cue, with the audio file name (less the extension) in the description column and the word "rel" in the activation column.
Here's the contents of a copy to clipboard:
Cue When Req'd Description Activation
Q1 page 1, as gauze goes out Seaside background Manual
Q1 Seaside rel
Q2 page 12 "you'll be singing home, sweet home" Blast from Stack Manual
Q2 Liner Siren rel
Q2.1 Page 13 Stop Seaside background Manual
Q3 page 22 "get off the boat" Blast from Stack Manual
Q3 Liner Siren rel
Q4 pg 23 "The Yellow Pages" Blast from Stack Manual
Q4 Liner Siren rel
Q5 pg 42 - Purser enters - "PULL" Shotgun blast Manual
Q5 shotgun rel
Q6 pg 43: BILLY ducks under stairs "PULL" Shotgun blast Manual
Q6 shotgun rel
Q7 pg43: "Good! PULL!" Shotgun blast Manual
Q7 shotgun rel
Q8 pg 43: "Miss! PULL!" Shotgun blast Manual
Q8 shotgun rel
Q9 pg 44 "Miss! PULL!" Machine Gun burst Manual
Q9 machine gun rel
Q10 pg 60 "You know a short cut?" -- drinks Dog barks Manual
Q10 BARK rel
Q11 pg60 "You're welcome" Purser & Billy exit Dog barks Manual
Q11 BARK rel
Q12 pg 61: "YEOW" pause Moon & Billy exit Dog barks Manual
Q12 BARK rel
Q13 pg61: "Why, it's right by your nosey" Captain exits Dog growls Manual
Q13 dog growls rel
Q14 pg 16, Moon YELLS Splash Manual
Q15 pg 66: THE OLD LADY enters Rain Manual
Q15 Heavy Rain rel
Q16 Fade out Rain Manual
Post by Mike Daniell » Mon May 07, 2007 7:13 pm
OK, I'll sort this out for 9.4. What's happening is the two entries are occurring because the sub-cue description is different to the cue description. I'll change this so that if there is only one sub-cue then only one line will print, using the description of the cue. The 'rel' is for the 'relative start time' which is obviously not applicable if the field is blank.
jkowtko
Post by jkowtko » Mon May 07, 2007 11:44 pm
Mike, also for the hotkey cues, the activation value (Hot Key) is in the Cue Type column.
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
d_korman
Post by d_korman » Tue May 08, 2007 5:40 pm
Thanks. Could the sub cues be indented slightly (possibly a configurable option)? I'd also like to be able to print only the main cue information, without the sub-cues.
What I'm looking for is a cue sheet that only contains cues that require the sound op to do something, and leaves out anything that is automatic. That sheet then goes to the DSM to mark up the book.
