Use SQS offline
erwin
Use SQS offline
Post by erwin » Sun Mar 05, 2023 7:23 pm
Hello
I have to test different things for which I unfortunately can't find a description or an answer anywhere.
I wanted to open one of my saved SQS files and got a lot of error messages that various devices are not connected.
I understand that very well and I answer with "ignore"
This because I don't want to drive a show, but because I want to see how I used to do it with the appropriate devices connected.
I have no chance to see the settings and parameters, SQS completely blocked my computer.
I can no longer exit SQS, the task manager does not start, I have to pull the power plug and die the computer :-(
Is there a way to start SQS offline ???
I would like to save an SQS file with a working setup from my theater to a USB,
take it to my office and adjust a few things there....
Or like to see what I put in at a previous show without building everything up completely
Thanks Erwin
Re: Use SQS offline
Post by Mike Daniell » Mon Mar 06, 2023 6:02 pm
Hello
Please email me the log file from a run in which this happened. Log files are created and saved in a folder named "SCS Logs" under "Documents", and the name of each file includes a time-stamp indicating when the log started.
erwin
Re: Use SQS offline
Post by erwin » Sat Mar 18, 2023 6:18 am
Hello Mike
I testet now again.
it is not possible to leave te Editor-Window..
>>> An RS232 Message must be entered (Control Message #1)
I can't ignore that Device and all of the Controll Commands are written...
Oh my Good Your own files will be attaked :-(
ERROR
The upload was rejected because the uploaded file was identified as a possible attack vector.
Erwin
SCS.7z
(57.17 KiB) Downloaded 214 times
