SCS 11.9.6 Available
Locked
Post by Mike Daniell » Tue Nov 01, 2022 2:11 pm
SCS 11.9.6 is now available on the Download page of the Member Area.
New and Changed Features in SCS 11.9.6
  • When creating or editing an Audio File Cue or a Playlist Cue, the 'Other Actions' button now includes options to trim all below -75dB or -60dB from the start/end of the file, in addition to the previously supported trim all below -45dB or -30dB levels.
  • MIDI Control Send Cues that use a Behringer X32 'Remote Device' can now also set Channel and DCA colors. (Sending scribble strip names is not yet supported).
  • Network Control Send devices in Production Properties may now be marked as 'Connect when required'. This will cause the device to be connected when it is first required by a Network Control Send Cue, if the device is not immediately available.
  • The splitter bar between the cue list and the cue panels in the main window now includes positioning limits to prevent the cue list or cue panels being completed hidden.
Bugs Fixed
  • Fixed the incorrect MIDI values sent for 'Go Scene', 'Go Snippet' and 'Go Cue xxx' in MIDI Control Send Cues that use a Behringer X32 'Remote Device'.
  • A memory error could occur on copying cues.
  • A memory error could occur if a video/image cue was started in the main window, then stopped in the editor, and then the browse button in the editor used to select another video/image cue.
  • Under some conditions, an Audio File Cue with current level of -INF would play at the 'Minimum Audible Audio Level' set in Production Properties / Run Time Settings, eg at -75dB.
  • The Production Property 'Default Screen for new Video/Image Cues' was not being applied, so the overall default screen (2) was always applied.
  • For Image Cues, the Rotate settings 'Flip Horizontal' and 'Flip Vertical' were not working due to a related change made in an earlier version of SCS. (They may have been working under some conditions.)
  • The fix in 11.9.5 to prevent an accidental double-press of the space bar activating the next two cues had the side-effect of also imposing the 750ms delay on other keyboard commands, such as up-arrow and down-arrow for moving through the cue list. The 750ms delay is no longer applied to cue list navigation keyboard commands.
  • The video/image display monitor on the main screen may stay black if the first video/image to be displayed has a fade-in time.
There is also a new demo cue file (SCS11_Demo_v2.scs11) containing additional demo features supplied by Dee Ireland.
Re: SCS 11.9.6 Available
Post by Mike Daniell » Wed Nov 02, 2022 2:24 pm
The SCS 11.9.6 setup files for registered users have been re-uploaded without the demo cue file and associated media files. Registered users rarely need the demo cue file again, but it is now separately available from a new link on the Members' Downloads page.
The reason for the change is that the new cue file and media added about 100MB to the sizes of the setup files, due to a number of video files included.
The setup files for the demo version of SCS, however, still contain the demo cue file and media.
Locked
