Using MS Powerpoint from Run Program Q gives flash of blue prog opening screen. Can this be avoided?
Mark Seyler
Post by Mark Seyler » Tue Mar 08, 2022 7:03 am
HI all.
Not used the Run Program cue before and I have problem. This is:
I'm using SCS to project a few images on Screen 2.
Then I want to open Powerpoint to run a sequence where slides move in and out of the screen as if running from a slide projector.
Unfortunately, as Powerpoint opens it gives a flash of the program opening blue background before actually opening the first slide image. Rather spoils the effect!
Is there a way of getting round this? I'm running a .ppsx file, as a slide show.
I can't have the program already running in background as it seems to unavoidably steal screen 2.... which has standard images projected before the slide show
PhilVale
Re: Using MS Powerpoint from Run Program Q gives flash of blue prog opening screen. Can this be avoided?
Post by PhilVale » Sat Mar 12, 2022 3:45 am
Mark,
Take a look at:
https://www.raymond.cc/blog/how-to-hide ... h-screens/
Half way down the article talks about how to disable spalsh screen of PowerPoint. - remember it wants <space>/s (check the article and you'll see what I mean.
Phil.
Post by Buyaicia » Tue Mar 15, 2022 2:56 am
Mark,
Do you know that Powerpoint can save a slideshow as a video file?
If you do not need powerpoint interaction, may be this could be the best way to play a powerpoint.
May be you can archive the same effect adding the fast start of video files.
