[Fix 11.9.1] Can't enter MSC commands
Post by djvomght » Fri Feb 18, 2022 2:35 am
Hello Mike,
we just run into following problem with 11.9.0. while entering MSC into a control send cue: The value for command format is not recognized and one can not enter cue numbers because the field for the cue number does not appear.
Regards Jörg
Re: Can't enter MSC commands
Post by Mike Daniell » Fri Feb 18, 2022 7:13 pm
Jörg, I've emailed you a link to a version that should fix this error.
SFGClaassen
Post by SFGClaassen » Sun Mar 20, 2022 8:33 pm
I have the same issue
