[Fix 11.8.3.2] Problem with slideshows
Gaiden
Post by Gaiden » Tue Oct 06, 2020 9:15 pm
Hello, I am having a weird problem with SCS.
I have 2 images.
Cue 1 is a slideshow with image 1 and image 2, with "repeat" function enabled.
Cue 2 is Image 1
Cue 3 is image 2
The problem is: Cue 1 finish, then start again (repeat is enabled), but only for 1 or 2 seconds. Then the show stops.
The weird thing is:
I have 3 laptops, all of 3 are running SCS 11.8.3.1
Laptop 1: Acer aspire VX 15 -> I have the problem
Laptop 2: An Asus laptop -> I have the problem
Laptop 3: SAME ASUS LAPTOP that laptop 2 -> NO PROBLEM (with same files/show)
Laptop 1 also have more images/videos related problems...sometimes a cue shows aligned to the left or right, and cropped, but if I launch same cue again, then it show centered (or no, is a random thing) Also, I have a "black time" changing from cue to cue (simple images cues)
log attached
Thank you
scs11_log_20201006_123935.zip
(145.64 KiB) Downloaded 40 times
Re: Problem with slideshows
Post by Mike Daniell » Wed Oct 07, 2020 3:23 pm
Thanks for the log file and explanation. I've been able to reproduce the problem and should have a fix ready for you in a day or two.
