[Fix 11.8.2.2] Freezing when copying and pasting sub-cues
d_korman
Post by d_korman » Wed Feb 12, 2020 9:59 pm
I've had several instances of SCS (latest version) freezing when I'm editing cues with multiple sub-cues, specifically, I think, when copying a sub-cue and pasting it further down the sub-cue stack in the same cue. I'll e-mail you a log file, the cue in question is Q12. The only way out is to close SCS from the main window, whereupon it asks if I want to save the changes. If I reply Yes, then when I re-open SCS the changes have been correctly saved and the cue runs OK.
davidcoliver
Re: Freezing when copying and pasting sub-cues
Post by davidcoliver » Fri Mar 06, 2020 8:28 pm
I have had similar problems not just with editing but when running shows. The app becoming unresponsive to the point I have to use task manager to shut it down and restart. I have been using SCS successfully for many years and a big fan. Am I the only one who is having problems?
Post by Mike Daniell » Fri Mar 06, 2020 9:03 pm
David,
A log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started. Please email me the log file from a run where this happened.
d_korman
Post by d_korman » Sat Mar 07, 2020 12:08 am
Yes, I had this happen last night - GUI freeze when running the show, editor was not open. I will send the log file shortly.
Post by Mike Daniell » Sat Mar 07, 2020 9:32 am
Thanks for the log file, Dave. The extra info logged enabled me to track down the cause of the freeze. I've emailed you a link to a version that fixes the issue.
d_korman
Post by d_korman » Sat Mar 07, 2020 9:24 pm
Thanks Mike, I'll give it a workout.
As always, the level of support you provide for this product is second to none, for which all us users are very grateful!
davidcoliver
Post by davidcoliver » Sat Mar 07, 2020 9:41 pm
Ran show last night (final dress rehearsal) in performance mode. It ran flawlessly, in the past I haven’t use performance mode preferring the extra information displayed design mode. Is this now the recommended mode or should SCS run OK in design mode?
