Hi Mike
Just got the newest SM-S version from Charlie Richmond. But it keeps crashing in SCS 11.8.1.1.
I have attached a log file.
Brian
[Fix SM-S 1.0.119] Soundman Server crashes
- scs11_log_20190611_085000.zip
- (99.33 KiB) Downloaded 51 times
Re: Soundman Server crashes
Brian,
SCS is timing out waiting for a response from SM-S after sending a command to assign an audio file to a playback channel. I've just run your cue file here, substituting one of my own wav files, and this worked perfectly. That's with the same version of SM-S and also with the same audio interface (Roland Octa-Capture). Can you email me the SM-S log file? This will be in the folder "SoundMan Logs" in your Documents folder.
Hi Mike
Here is the log file from SM-S. I hope it´s the right one.
Brian
Brian
- SM_Log_Tue_Jun_11_08_49_41_2019.zip
- (3.91 KiB) Downloaded 48 times
