List of some bugs
Vellemum
List of some bugs
Post by Vellemum » Tue Dec 04, 2018 2:38 am
Hello Mike,
First things first: I like SCS a lot!
I programmed a show which was originally made in QLab and learned a lot about using the program.
I had to find some solutions to make it work the same as in QLab and now it is working almost :wink: flawless.
Attached the diagnostics file. I will send you the scs-files in a mail to support@showcuesystems.com.
Here's what I find during programming and testing with the show send to support-mail
Bugs? in 11.7.1.3
• when a note cue is hidden you still see this cue in the cue-panel of the main window. (see cue HK-00)
• in cue 'VOOR 4.5' I can't remove a level point. It's greyed out. Perhaps I'm doing something wrong?
• when cue 7 is playing and I click in the cue-panel on the waveform to skip some time, the next sub-cue is (7 <2>) is completed immediately. Also the play control of 7 <2> is blocked, but not the stop. Is this normal behaviour? In that case the play-button should be greyed-out to make it clear.
• when updating the Rel.Start time of cue 7 <2> in the editor and then go back to the main window and start cue 7, you see the countdown is counting down from the updated time but the information under the slider of this cue 7 <2> is still on the previous Rel.Start time.
• the colour of sub-cues are correct as long as the previous cue is playing, but as soon as the previous cue is finished and the cue-panels are updated only the first sub-cue has the right colour. When clicking in the upper panel on this 'next' cue (the one with the sub-cues), the colour of all sub-cues are updated correct.
When I'm programming sometimes I have more of this 'not correct updating' problems when switching between editor and main window. Most of the times it helps when clicking in the cue-list on another cue and then go back. After this everything is updated correct.
Hope you can find the problems and solve them before releasing the new software.
Best regards!
scs11diag_20181203_165359.scsz
(140.88 KiB) Downloaded 140 times
