SCS 11.7.1.1 Release Notice
Locked
Post by Mike Daniell » Fri Aug 03, 2018 4:01 pm
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.7.1.1 from the Download page of the Member Area. This is a bug-fix version so the release date (for download purposes) has been back-dated to that of SCS 11.7.1.
You can optionally download an SCS setup file that includes the installer for LAVFilters (included with permission). If you do not already have the latest LAVFilters installed then we strongly recommend using the download with LAVFilters if you want to play any video file cues.
Changed Features in SCS 11.7.1.1
  • Some modifications have been made to reduce the amount of screen refreshing that occurs.
Bugs Fixed in SCS 11.7.1.1
  • Fixed an issue that could cause some SCS Cue Markers to be skipped.
  • When playing several video cues close together, the playback cursor could freeze and a video control may be freed early.
  • When using ASIO with gapless streams directed to more than one audio output device, the second and subsequent audio files in the stream would not play.
  • When playing a Playlist Cue using a gapless stream, the Playlist Cue would stop after the second track.
  • The 'For MTC' property was not being saved in Control Send MIDI devices in Production Properties.
  • Added some missing 'OEM' keyboard codes to the list of available shortcut keys.
Some SCS features may not be available in all license levels. Please check the 'Feature Comparison' section of the Help for details.
Locked
