Small possible bug?
I have assigned the following shortcuts for;
Master Fader Mute - m
Master Fader Down - , (comma)
Master Fader Up - . (period)
Master Fader Reset - / (slash)
For the last few releases the Master Fader Reset shortcut only works a few times and then stops responding. The other three shortcuts mentioned all continue to work normally. This is the case on several different PCs all running Windows 10.
[Fix 11.7.1.1] Shortcut for Master Fader Reset Doesn't Work
Re: Shortcut for Master Fader Reset Doesn't Work
Fix ready for 11.7.2. I'll email you details of a pre-release early next week. It was caused by SCS not fully handling Windows 'OEM' virtual keys, which include VK_OEM_COMMA (< ,), VK_OEM_PERIOD (> .) and VK_OEM_2 (? /) amongst a few others. I have now added all the VK_OEM codes.
