Previewing tracks before opening gone?!
mattcoomber1
Post by mattcoomber1 » Thu Jun 08, 2017 12:46 am
Hi, I don't know if it is me / something not set up right but I used to be able to preview audio tracks in a folder. A play button and level control came up at the bottom of a folder when I went to add an audio file. I could then quickly play through a folder of sound effects for the director before adding them to the cue file. It seems I can no longer do this running the latest version and can only listen to the track once it is inserted. Has the feature been removed or is it something I haven't got set up properly?
Matt
BritGeek
Re: Previewing tracks before opening gone?!
Post by BritGeek » Thu Jun 08, 2017 9:15 am
I'm pretty sure Mike told me a while back that the audio preview feature isn't available in the file selector window for the 64-bit version, so if you recently changed from a 32-bit to 64-bit installation that would explain why you're no longer seeing it.
Tim.
mattcoomber1
Post by mattcoomber1 » Sat Jun 10, 2017 12:30 am
Thanks Tim, that would explain it, that is exactly what I did. First time using 64 bit on the latest update :)
Matt
Post by Mike Daniell » Sun Aug 20, 2017 11:51 am
This feature will be reinstated in SCS 11.7.0. The revised code no longer directly uses a Windows API and so is available in both 32-bit and 64-bit versions.
