Hi! I am beating my brains out trying to link my ETC Expression 3 light console to SCS. I have been able to fire cues via MIDI to the Expression 3, no problem.
What I'm trying to do, however, is use my C/D Go button on the console to fire the "GO" button in Show Cue Systems. I cannot get it set up to work. When I test the midi, I receive the following packet: F0 7F 01 02 01 01 32 00 32 00. I am using MSC and have the correct MIDI channel and Device IDs setup. Still no luck.
Any help would be appreciated. Thanks!!
Steve
MIDI Show Control from Expression 3
Re: MIDI Show Control from Expression 3
Steve,
