[In 11.5.0] SCS now available in 64-bit (x64)
Post by Mike Daniell » Sat Jun 04, 2016 10:18 am
Special announcement: As from 11.5.0 RC3, SCS is now available in both 32-bit (x86) and 64-bit (x64) formats.
The only restriction with the x64 version is that xVideo is not available as this is only supplied as a 32-bit DLL. TVG is therefore the default video playback library in the 64-bit version.
We recommend you use the 64-bit version if you have a 64-bit machine as this should perform faster. Note that on a 64-bit machine, Windows supports 32-bit applications via an x86 emulator, so this is not as efficient as running a 64-bit application.
See the the Release Notice for more info.
