[Fix 11.5.0] SCS Crashing in options menue
davidcoliver
Post by davidcoliver » Wed May 11, 2016 6:39 am
SCS Crashing when I try to change shortcuts and other options.
Message for short time "invalid memory access" then "Show Cue System has stopped working"
Install on new PC.
David
Re: SCS Crashing in options menue
Post by Mike Daniell » Wed May 11, 2016 8:08 am
I've emailed you details of a tracing version to run.
samforbes
Post by samforbes » Sat May 14, 2016 1:12 am
I've had the same issue but when trying to renumber Que's. Tried on another pc and got the exact same issue at the exact same point
Post by Mike Daniell » Wed Jun 08, 2016 5:44 pm
This seems to be a strange Windows 10 issue, but from similar reports I've received you should find this fixed if you use the 64-bit version of SCS. This is now available as a release candidate of SCS 11.5.0.
