Situation: AudioCue with autostart, "starting after the end of the previous cue" The new cue will not start. No reproduction.
11.3.6 Until he ran off, but playing on the same audio output as the previous cue, no matter which output is set. 11.3.7 Since the cue does not start happening at all.
Workarround far: 0.1s "start before the end of the previous cue"
Auto Start: "Start after the end of the previous cue" error.
Re: Auto Start: "Start after the end of the previous cue" er
Hey. I got a similar problem. Start cue 2 second before end of cue q73 doesn't work. Changed it to ae (which is not nice) works once. Today I will try the 0.1 seconds after end.
Which works but is a bit calculating is seconds after start .
Greetings
Running 10.4.0
Greetings
Running 10.4.0
