[Fix 11.3.5] Problem with resuming hibernated cues
Post by djvomght » Mon Oct 20, 2014 4:22 am
Hallo Mike and all,
during yesterdays rehearsal I run into following problem: I have a cue file with audio cues to be played for some seconds, then hibernated and resumed some time later. Resuming the hibernated cue fails. The cue is indicated as playing, but no audio appears. All other cues play ok. Problem occurs on different machines with different systems (XP and Win7) and with SCS 11.3.0 and 11.3.4 (and all versions between, I guess). With 11.2.5, everything is fine. I attach the diagnostic file as zip.
Regards Jörg
scs11diag_2014-10-19_200945.zip
(4.82 KiB) Downloaded 39 times
Re: Problem with resuming hibernated cues
Post by Mike Daniell » Mon Oct 20, 2014 5:42 pm
I've emailed you details of a new version to try. The fade-in from a hibernated cue was not being handled correctly by the new level envelope processing.
